- Mar 19, 2001
- 7,740
- 11
- 81
Per the instructions for updating my BIOS.
How to update the BIOS (For Award BIOS)?
Step 1: Make sure the downloaded BIOS is applicable to your motherboard.
(Please check the model and the version of your motherboard.)
Step 2: Power on the system and enter the pure DOS Mode.
Warning: If you try to update BIOS under Windows DOS box Mode,
it will cause unexcpet damage for your system.
Step 3: Build a new temporary subdirectory, then copy the file to this
Subdirectory.
For example: copy the "AWDFLASH.EXE" and "DGL200.EXE" to the
directory.
Step 4: Go to the temporary subdirectory and run the downloaded file.
It is a self-exactor file, All you have to do is execute this
file. Please remember the full filename of "*.BIN" file, which
is one of these de-compressed files.
Step 5: Run "AWDFLASH.EXE /CC /CD /CP".
Notice: If your motherboard is based Intel 430VX or earilier,
please use AWDFLASH.EXE v5.34. Don't use AWDFLASH.EXE v.7.05
or later.
Step 6: Type the filename of the new BIOS according to the instruction.
(The filename is " *.BIN ")
Step 7: Press "Y" when AWDFLASH.EXE asks whether or not you are going to
save the old BIOS.
Step 8: Type a filename for the old BIOS. Then Press "Enter."
Step 9: Type "Y" when AWDFLASH.EXE asks if you are going to update the BIOS.
(NOTE: Don't power down the system or press <Alt+Ctrl+Del> before
you finish updating BIOS, or it will cause the system to hang
permanently.)
Step 10: Please reboot your computer after you finish updating the BIOS.
Step 11: Press <Del> to enter BIOS setup to execute "LOAD SETUP DEFAULTS."
Step 12: If your motherboard has built-in SCSI interface, press
<Crtl> + <A> enter SCSI BIOS setup to execute "LOAD DEFAULTS."
Notice: If your model is P55TV, please use 7860cfg.exe to setup
SCSI options due to we remove SCSI BIOS setup program
from system BIOS.
Subdirectory.
directory.
or later.
save the old BIOS.
permanently.)
from system BIOS.
