What is Priming, and how do i do it?
Sounds like you're talking about Prime95. Just google for it. It'll be at a site named mersienne.org (sp?).
D/l and install. Under options select Torture Test etc. Used to test stability, especially after OCing etc.
It'll loop continuosly. Let it go for 12-24hrs. Should be zero/no errors if your PC is stable.
Fern
check frame rate? first you wanna spend a few hours levelling up without saving(this should heat things up good). then hit alt-f4 to bring up the frame rate.
I think it depends on the game dude. I think there's a utility called FRAPS that you can download to do it also. Believe it's freeware or shareware.
Saying it that way is an extremely sloppy and lazy use of language. Who's so lazy that they can't type running Prime95 instead of "Priming"???
.bh.
