Here you go:
PCI patch:
Down near the bottom you will find a working link for the pci16W.zip patch.
Description:
Windows 95/98?ÅPCI System Management Bus?Windows 98 Second Edition?Windows NT
This is kind of a odd problem though, this patch use to be on Via's page for the longest time until a few months ago when it disappeared. I think the newest 4in1's (or miniports for some AMD chipsets/Hybrids/Asus ect.)have incorporated this patch or made it obselete. In the few hundred builds I've done lately I have needed to use this patch about 25% of the time, even though some systems with exact configs require it and the next one doesn't.Strange...
Installing it can be tricky as well, some times you can run the setup program and other times that won't work and you need to update the driver from Device Manager and point to the inf file. Hopefully one will work!
