Originally posted by: PorBleemo
Originally posted by: Garion
How are you seeing packet loss? From where to where? Are you seeing it from your PC to your router, or is it across the Internet?
If it's across the Internet, it's typically caused by congestion somewhere out there - Too much bandwidth trying to squeeze into too small of a pipe. It might also be caused by congestion in your local segment - Cable modems are more prone to this than DSL networks, however.
- G
Across the network from the computer to our firewall. Using ping as it's the best tool I know of for that.
If you're seeing packet loss across a LAN, you have a few possible culprits:
Bad cabling
Bad speed/duplex negotiation
Bad NIC
Bad switch port
Interferece on the wire (i.e., florescent lights, etc.)
Work on the variables - Try a different PC, try a different switch port, try that PC on a different cable that's known to be good, etc.
One note - Many PC NIC drivers hide a lot of L2 errors from the stack - You might be seeing a lot of errors and not know about.
Also, different kind of errors mean different things. What are you seeing? FCS, CRC, collisions, runts, giants, etc?
- G
