What is max wattage fan i can use on hardcano 7 ???
ChampionAtTufshop
2,667
whats the max wattage fan i can use on hardcano 7?
(any information regarding the matter seems to be eluding me...)
ive got a 9.1W .... do you guys think i can use this without blowing up the unit/fan lol? :Q
Noid
2,390
193
uuuuh.. you mean a Volcano 7?
I dont see any adverse problems as long as you dont plug it into the MB headers.
I used an adapter once that fit a 90mm fan over the top of the standard HSF unit.
ChampionAtTufshop
2,667
no not a volcano 7
thermaltake hardcano 7
linkage
i mght use the fan controller, but i want to make sure it can handle a 9.1W fan
does anybody know?
or shall i "guess and check" heh
godmare
5,121
I understand the Vantec nexus reports handling 18 watts per channel.
Have you no documentation giving such indication? Is it possibly printed or otherwise advertised on the hardware?
ChampionAtTufshop
2,667
there was something written on it when i ripped it apart, but i forget what it was lol
anyways, i got a response from thermaltake saying it just manipulates the amount of voltage given to teh fan (duh) and a 9.1w fan should be ok
thx anyways :)
