what is heatsink soft compound?
watchmen77
24
ok, this is first time i actually order a heatsink, i usually just use the one that came
with my retail cpu box. but that one really not that great, my amd cpu 1.4mhz now always at 50-56,
so i decided to buy a new heatsink, i bought svc gc68, it comes with a small packet says
heatsink soft compound on it, i never saw these before.
what can i do with it? do i apply it on the surface of my heatsink?
thanks for help.
fatbaby
Banned
May 7, 2001
6,427
that is material to make up for the gaps between the hsf and your core.
Take a small plastic bag, add a little heatsink compound on it, and rub it on the base of your svc gc68 in circular motions clockwise and counterclockwise. Wipe off the excess with a lint free cltoh
Then take a little bit of that compound and spread it on the core as evenly as possible with a credit card. All you need is a paper thin layer of it on the core.
