what is going on with my CPU temp
emt8q5
49
I just installed Mother board monitor 5 and went to check my CPU temps. MBM 5 says my CPU is running at 127C (yes, celsius, not Farenheit). I immediatly restarted computer and went into the BIOS which said my cpu temp was 39C. Is this some sort of error or what? can a CPU even run at 127C stably (My system is running perfectly stable, left on all of last night without a problem)? could my CPU drop from 127C to 39C in less than a minute (as I went from windows desktop to BIOS temp setting? I am not overclocking anything, and have a stock HS on the CPU. Here is my system.
Lian-Li PCB-7 case w/ 3 fans
Mad Dog 500 Watt BTX powersupply
MSI K8N NEO 4 Platinum
AMD athlon 64 3200+ w/winchester core (not positive on the core) and stock heat sink
2x 512mb Crucial Value Select pc 3200 RAM
PNY Geforce 6600 GT pci-e
74 g Raptor
160 g Seagate Baracuda
chaudharymic
94
No it cant run at 127C, you picked the wrong board or sensor type. That is a pretty stupid question, no offense.
Jiggz
4,329
Since the system is running fine, I would suspect MBM reading is erroneous. I wouldn't worry about it. You can try other mobo monitor software to see if the error is on the MBM software or on the probe.
volrath
451
127 is the maximum mbm can read... IE, it is getting no reading. select your motherboard type in the wizard.
