OK, here's my story. I have an T-bird 900 on a Soyo K7VTA motherboard with the onboard UDMA66 controller. I also have a 20gig Western Digital UDMA66 drive as master and a 6.4gig WD UDMA33 drive as slave on my primary controller. My secondary controller has a DVD and a CDRW.
Here's the trouble, when I have UDMA66 enabled on my master drive, I can't get my slave drive to run properly with UDMA enabled. MP3s will skip, scandisk will freeze on the first sector for a thorough scan, and sometimes the FAT table becomes corrupt.
However, when I disable UDMA66 on my master drive so that it is limited to UDMA33 (through software provided by WD), I can get both drives running perfectly with UDMA.
So my question is, does anyone know what the problem is? It seems that I can either have fast UDMA with one drive only, or somewhat slower UDMA for both drives, but I can't have both. I don't think it's a problem with the IDE cable, because the master drive would run fine with UDMA66 (according to HDTach, it was performing at 66 speeds).
So, I'd really appreciate it if someone could solve this riddle for me.
