What is Glib? Trying to instal the codec for XMMS to allow for avi playback....
Chobits
230
[root@localhost root]# cd ..
[root@localhost /]# cd download
[root@localhost download]# cd avi-xmms-1
[root@localhost avi-xmms-1]# cd avi-xmms-1.2.3
[root@localhost avi-xmms-1.2.3]# ./configure && make && make install
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++ ) works... yes
checking whether the C++ compiler (c++ ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking for Cygwin environment... no
checking for mingw32 environment... no
checking host system type... i686-pc-linux-gnu
checking build system type... i686-pc-linux-gnu
checking for ld used by GCC... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependant libraries... pass_all
checking for object suffix... o
checking for executable suffix... no
checking command to parse /usr/bin/nm -B output... ok
checking for dlfcn.h... yes
checking for ranlib... ranlib
checking for strip... strip
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions... yes
checking whether the linker (/usr/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking whether -lc should be explicitly linked in... no
creating libtool
checking for glib-config... no
checking for GLIB - version >= 1.2.2... no
*** The glib-config script installed by GLIB could not be found
*** If GLIB was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the GLIB_CONFIG environment variable to the
*** full path to glib-config.
configure: error: *** GLIB >= 1.2.2 not installed - please install first ***
What is that and where do I find it? I'm using RH 9.0 if anyone careS :D
Chobits
230
um......I went to www.gtk.com and downloaded and installed glib 2.2.0 and I tried it again and it demands 1.2.2
isn't it backwards compatable? Must I downgrade just to get it to work? Thanks
Barnaby W. Füi
12,343
gtk1 and gtk2 are very different, if something needs 1.x then you need to use 1.x. Also, you should only install things as root, there is no need to compile them as root (and there have been backdoors that install themselves that way).
