what is fan size in Powe supply?
Sorgon2
420
The intake fan on Enermax power supplies is usually a 92mm fan and the exhaust is usually a 80mm fan. I assume most power supplies are built this way. If you are looking for power supply fans try here.
Sundog
12,342
Most power supplies are not built like an Enermax w/2 fans. Most power supplies have one 80mm fan.
MrThompson
820
You can always add a 92mm fan to the bottom. My favorite 400 watt PSU does not have room for a fan inside the case so I have done this a few times. Just don't touch the caps in the PSU while doing the mod. They carry a potentially lethal voltage.
whitelight
3,505
usually 80mm. but you can always take apart your psu and measure the size of the fan... that's what i did with my psu when i was bored.
