SilverMirage
Building a computer for my friend who needs a computer in dorm...wants to OC when he plays games or uses CAD software, but wants to tune it down for using microsoft word and such (or when it is idling). Which would give the best combination? Will the performance difference be dramatic? Will the heat disipation difference be dramatic? Since I don't think either will give the best of both worlds, which in your opinion would be best?
AMD Mobile Athlon XP 2600+, 47 Watt - AXMG2600FQQ4C
OR
AMD Mobile Athlon XP 2400+, 35 Watt - AXMD2400FJQ4C
(just in case you are interested...)
AXMA... - Mobile Athlon XP-M Desktop Replacement OPGA, 72W(Model 8/10)
AXMH... - Mobile Athlon XP-M Mainstream OPGA, 45W(Model 8/10)
AXMG... - Mobile Athlon XP-M Mainstream OPGA, 47W(Model 8/10)
AXMD... - Mobile Athlon XP-M Standard/Low-Power OPGA/µPGA, 35W(Model 8/10)
AXMS... - Mobile Athlon XP-M Low-Power µPGA, 25W(Model 8/10)
AXML... - Mobile Athlon XP-M Ultra Low-Power µPGA, 16W(Model 8/10)
P.S. How does the A64 mobile compare...if he wants to spend the extra few bucks
OR
