What is a good QUIET cooler fan?
GTdrew
159
The fan that came with my volcano II is driving me crazy :( seems like it if spinned a little slower it wouldnt be a problem. What ia a good QUIET fan to replace it with. Im running a 1 gig TB on an Asus A7v133a. not overclocking it at all and have 2 other case fans.
I though about replacing the entire heatsink and fan but that thing was a biotch to get on wouldnt want to try and get it off :). Also what are some good sites to order this stuff from with low shipping ?
Thanks for your help
Drew
elimcpheron
127
i would go for a panaflow 80mm fan, check out the hot deals forum and they have a great thread on where to find panaflow fans for cheap!
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
You need a decent 60mm fan as a direct replacement, one of the mid-20's cfm sunons would probably work fine. try 2cooltek, kdcomputers, etc. I think kd carries the sanyo denki pico ace 60mm, but it might turn out to be a little wimpy, and they're expensive....
