- May 16, 2002
- 897
- 0
- 0
Hi
I would really appreciate some light on what 8b/10b encoding format is, when you serialise and transmit a 10 wide parallel bus at say 10Mbps for the bus, and how it is affected by the 'K28.5 comma character (0011111 negative beginning disparity)' signal that aligns the data bits at the receive deserialise end, and also how the insertion of this comma affects the effective data rate of the whole transmission over the serial bus between the serialiser and the deserialser. IE does it increase the data rate from 100Mbps to 125Mbps?
