What is 3 Pin Blue and Black Power Supply Cable?
RobDMB
434
I am putting together a case and from the power supply there is a blue and black cable that I have no idea what is is for? Could anyone tell me if this shold be connected to something? Thanks, Rob
RobDMB
434
The power supply is a Smartpower 2.0 350 watts. I think it is a fan connection. I'm wondering do I connect this to the motherboard where it says chasis fan or no - would chasis fan simply mean the regular case fan?
RobDMB
434
Anyone know if I should connect this cable? I want to boot this system up but I'm just worreid about this cable.
imported_stev
368
Just connect it to a chasis fan connector on the motherboard. I have a 400 W SmartPower and that's what I did. However, it's not required, according to the manual, it just allows fan speed monitoring.
dev0lution
472
It's the cable that the Antec PSU uses to vary fan speeds for the PSU fan and fan-only connectors. Connect it to a chassis fan header on your motherboard like he said...
