What hs/fan chipset would work on DFI NF4 ultra
cuti7399
2,583
I just got this board and it doesn't have the chipset hs/fan. Would you guy recommend some that would work? I was thinking about using a socket 370 hs/fan if it would work!! Thanks
Budman
wow you must have gotten a very old version of the board,they all come with a 40mm fan on it now.
Just screw on a 40mm fan.
Budman
Originally posted by: cuti7399
only a 40mm fan? what about a heatsink?
If the board didnt come with a heatsink then you should RMA it right away.
booting it without a heatsink will surely kill it.
vanvock
959
It has to be low profile so the vid card doesn't hit, seems like someone posted 14mm height? Check on Vantec(iceberg?) Sorry I don't have any details, search the forums, this topic has been covered in there somewhere
