What Heatsink/Fan better than stock work on Gigabyte K8nxp SLI Board??
asmielia
14
I have a Zalman 7000Cu (the original model). Before I had to RMA my Gigabyte board, I got it working perfectly on the motherboard. It didn't work out of the box, but all I had to do was contact the Zalman reseller here in the UK, and for no charge, they sent me a new backplate with new nipples. It got to me within a day. Pretty sweet service if you ask me. I had some really good temps as well, even overclocked and overvolted (3200+ @ 2.65 ghz, 1.55V), it never went over 47 in a not spectacularily ventilated case.
Adrian
asmielia
14
And by the way, the newer 7000B comes with its own backplate that's the same as the one they sent me, so that will work out of the box. All you need to do is remove the plastic retention frame that comes with the motherboard which is pretty easy because of the plastic push pins.
Adrian
