What hardware do I need to...
Submit
793
I would like to record clips from my TV. I have both S-video and RCA outputs on my TV. I am not sure, but I believe I need a video capture card and a TV tuner maybe.
Questions:
1. Can I get this on one card? PCI type slot preferably
2. Which feature are important to get ?
3. Which brand/model is most popular/recommended ?
I will not be doing this professionally so I don't need professional quality equipment.
This card(s) would be installed in 'AMD Box' under System Rigs.
Thanks for any advice.
Adrian
Crusty
12,684
ATI TV Wonder
Contains everything you need to watch TV on your pc and record them as well.
Submit
793
Can I get one that will pop into a PCI slot? The only one I found at newegg.com is this one link which is external and connects via USB.
Model or product link, please ?
Thanks
Adrian
Submit
793
After some more research I am assuming this link is the product I need. Model # 100-703060 . Can anyone see anything I missed or this product will not do, which I listed above ?
Also, has anyone bought from pccdepot.com ? ...resellerrating.com is down...
Thanks
Adrian
Submit
793
I also foung this one link at Staples for $30 more. I would have thought the two products are the same, but the boxes look a bit different, and also the price is a bit different.
confused...
