What hardware do I need to burn small cds for an mp3-cd player?
Infohawk
17,844
I have a cdrw on my computer. The philips mp3-cd player seems to use a small cd. :/ Are these small cds readily available at stores? Can they be burned in regular cd burners? Thanks
gsaldivar
8,691
Yes.
Yes.
Burn them like a regular CD-ROM. There is a 210-220MB limit per disc.
Infohawk
17,844
Thanks!
If they are smaller how do they stay in place when they're being burned? :/ Does Nero handle the burning? Are there cd-rw versions? :/ How much do they cost?
Ionizer86
5,292
Inside the CD-RW's tray is another smaller tray that fits these small CD-R disks. Burn them just like usual. As long as you have a tray loading drive and not a slot loading drive, you're good :)
