Originally posted by: Mrpilot007
I do believe everyone failed to answer your original question:
If Superman was able to reverse the direction of Earth, everything would go from 1000mph to -1000mp, assuming he reversed the earths spin exactly, thus everything would quickly become chaos. The conservation of energy would apply and I would have a really bad headache, assuming I still had a head or body. Lois would still be dead and Superman would sit alone on an Earth that is now rotating backwards. If he decided to return Earth to its previous spinning state, he would send yet another abbrupt change in motion furthur destroying everything on Earth.
...OR...
As what happens in the movie, he reverses time for everyone on Earth for a brief period to before Lois dies. He has now successfully reset history back to its previous state and everything now continues normally from that point on. No paradox exists because he undid her death, saved her life knowing she would die if he let the events continue as they had previously and everything else continues. Superman, of course, is still living relative to the old time and is still a few minutes older than everyone else on Earth, but that doesn't matter because he was the one who caused time to reverse. He didn't really even travel back in time either, he undid time.
Pilot, while I somewhat agree with your first answer, your second answer seems a bit . . . well, very confusing.
Time is a relative concept, and therefore cannot be "undone." According to the laws of physics, one may travel freely through time by breaking the light barrier, however, by purposefully changing history, you create one of two events:
1. An alternate universe (read "timeline") is created and time continues. However, since you have gone back in time, there are now two of "you." But by doing this, you destroy the universe you came from, leaving only the universe you create to exist. (Heisenberg uncertainty principle would theoretically allow you to travel back in time and exist in two places at once, since you cannot be certain of the state of the atoms in either of your bodies. You should even be able to interract with yourself, shake your hand and hug, as the space between cells and atoms of your bodies would still be great enough to insulate from any laws of physics dictating that two objects cannot occupy the same space. Timecop was wrong
or
2. According to the multiverse model, Superman would travel back in time to another universe, save that universe's Lois, and then continue onward (still, having two Supermans now existing simultaneously, as they are actually two different people). The original Lois would still be dead, and that universe would go on without its Superman, unless he found a way to return. However, in returning, He would have changed nothing in that universe.
Hope that helps.
