What happens if I remove a MB's button battery ?
Paolo
424
If I remove a motherboard's battery which I think is near exhaustion to replace it, doesn't this reset the bios to default ? Or does this ruin the bios ? In short is this safe to do ? :confused:
spanky
25,716
4
i think it will reset the bios. don't worry, it's pretty safe... unless u spill a cup of water on the mobo while changing the battery. but hey... what are the chances of that happening.
Kelvrick
18,422
I'm pretty sure that just keeps your bios settings. Your bios will reset to default configs, and you'll have to chagne everything again, but thats it.
<== monkey dance
Zim Hosein
Super Moderator | Elite Member
65,293
403
Paolo, it's safe to do, all removing the CMOS battery does is reset the BIOS options to their default. :)
