I don't understand the question. Are you talking about having an ethernet NIC and a wireless adapter in the same system? That's pretty common, and on laptops where you can switch off the wireless with a case button Windows will use the ethernet if it's available. On a desktop system you may have to go in and disable the wireless adapter. I'm not sure about that.
