Hi all,
I'm wondering if anyone can diagnose this problem. I can only guess as to the cause.
Basically I have an Athlon XP 2000 system on an Nforce2 Biostar M7NCD Pro system board. (never overclocked) System has been running fine for over a year.
I'm using it the other night just fine browsing the web. All of a sudden the system resets totally randomly. It then started to reboot as it normally does EXCEPT when it was loading Win XP the status blocks were moving across as usual but hard froze before fully loading.
At that point I turned off the system and waited a few seconds. I then turned it back on only to have the monitor not come on and for the system to repeat a single beep every few seconds.
I tested the RAM and AGP card (radeon 9700) in another system. Worked fine. I removed all the PCI cards. Same beep.
I tried to clear the CMOS with the jumper as well. Still nothing.
Best I can figure is for some reason either the CPU or system board (the only two components I didn't test on a different system) died after over a year of no problems.
Am I right in this conclusion? If so, what could have possibly caused this to happen? I've never experienced something like this before. It was totally random and unusual.
