What happen if i put too low Vcore voltage?
hunkeelin
275
In the intel 3820 spec it said "to be safe don't go over 1.4" let's say a 3820 @3.6Ghz requires 1.25V however i set it as 1.0 what will happen? will i endanger my system?
LoneNinja
825
You won't kill/damage it from dropping the voltage, your just at the same risk of instability underclocking as you would be overclocking.
Rvenger
Elite Member <br> Super Moderator <br> Video Cards
Apr 6, 2004
6,283
No but you might corrupt your windows installation :p
Diogenes2
2,151
As long as you set the multiplier to 12, you should be fine..
