what guage speaker cable for Polk R50 & Onkyo 605
LOUISSSSS
8,771
58
i just got my polk R50's and my Onkyo Sr605.
i also have some 18 guage speaker cable from Belkin (pure AV), would those work fine?
new to HT
Shawn
32,236
53
It depends how far you are going to run the speakers. I would say though that 18 gauge is too small.
mshan
7,868
What do the manuals say?
If I had to guess,16G is probably what is recommended.
Just get some 16G stranded oxygen free copper speaker cable and see if that sounds sufficient for your needs. Monoprice.com or even a local car stereo store should have it pretty cheap. Some have a tinned return leg, but I don't know if this would have any sonic degradation.
LOUISSSSS
8,771
58
wait so 16G is bigger than 18G? no idea about this stuff.
i'm probably going to be using about 3-5 ft of speaker cable from the receiver which is right next to my tv where the speakers will be...
destrekor
28,799
359
correct, the lower the number, the larger in size. 12ga is larger. I believe it has been said that 16ga is good for most applications, up to lengths of 25ft. If you have any longer runs, look to 12ga then.
sdifox
100,951
18,107
new to HT
length? I just buy 12GA, not all that expensive to start with, like $1.50 a metre.
Auric
9,591
Also consider lower gauge is less flexible -even more so with lower quality, so erring on that side can have its disadvantages beyond price. I would rather get the size required and spend the difference (versus just bigger) on better quality (i.e. more flexible and less likely to corrode).
zinfamous
111,947
31,484
I have the same front speakers and receiver...I use 12ga that I bought from Monoprice. I have 2 runs that snake across the floor, around doorways, and ceiling of my apartment, so I figured I'd go with the safe bet.
