Gibson486
Getting ready to do a tran. flush on my Mazda 3 again. First time, it was done by the dealership. I suppose they used OEM fluid. The fluid they use does not last that long. It only lasted 20K the first time (it was all brown and yucky). Looks like it is time for another flush....At $12 a qt, I think I will avoid the Mazda brand fluid.
What would you recommend for M-V fluid (not the same as Mecron-V)? SO far, all I see is mobile 1 and Amsoil. They are both about $8 a qt. Any other company I should consider?
***update***
post 29
***update***
post 29
