Page 616 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
clamum
26,252
403
Of course my cheap ass company isn't giving employees a day off today or Monday (my bro had to tell me he gets today off, mother scratcher). So I'm sitting here with just a few other employees, super quiet, not much going on. WHY. FML
lxskllr
58,008
8,242
My truck's in the shop, and I had to drive the Malibu for work today. I can't type enough expletives to describe how much I hate that car, and how unsuitable it is for field work. I'm now without a vehicle til... sometime... However long it takes them to fix/replace the rear end. I don't really /have/ to go out, but I don't like being trapped :^(
12,648
My furnace started to intermittently make lot of noise again, it seems to always do it when the heat turns off and it runs the blower a bit after. I think when it does that it must be running at a higher speed or something and it causes lot of rattling. I really need to get in there and see what the issue is. It also makes lot of noise when it starts but it's a different noise. That one is harder to track down since I don't hear it as bad when I'm near the furnace but when I'm up stairs. I think something is vibrating and the way it reverberates through the ductwork makes it louder upstairs. I suspect the draft inducer motor but it looks fine when I check it. Nothing loose etc.
I may have to take out the blower assembly and clean and re-balance it, and that's a pain in the butt. I don't know why the duct cleaner guys never touched it, it was half the reason I hired them! Then they tell me they're not qualified for it, whaaa?
snoopy7548
8,131
5,156
Speaking of furnaces, have you ever replaced an inducer motor? My gas furnace emits kind of a high-pitched noise only when the flame is on. I think it's the inducer motor bearings. They probably need some oil, but I was reading about new furnaces not having an oil port. It's been like this for over a year, but it has not gotten any worse. A replacement inducer motor is only $87, and apparently easy to replace on my model so I may just do that.
lxskllr
58,008
8,242
Fathead's been looking pretty bad lately. He got into a fight, and is missing fur on his face/neck. His face also doesn't look quite right, but I can't put my finger on what's wrong. Add in his gimpy gait, and he's not doing so well. Still makes it down here for food, so I guess he's good enough. I'll miss him when he's gone.
12,648
Never replaced one myself, but does not look TOO involved. If I suspect that is what is causing the noise I may actually look at replacing mine, though it seems to run smooth when I'm in front of it. Like if I put my hand on the motor I don't feel any vibration. I did replace a pressure switch once though. :p
Charmonium
10,015
3,180
I hate that. Even on cloudy days I have to squint if I don't have my shades. You get weird looks when you do that, but f*** it.
lxskllr
58,008
8,242
My new splitting maul is as mediocre as I remembered. Hard to complain for what I paid, but it has a very small niche where it's useful. Between an axe, and maul/wedges, it doesn't have a very useful range, and splitting with it sends the wood flying. I have to stop, and pick the wood up for more splitting. With the maul, many times I can split a round, and keep the pieces together. Pull them apart when I've gotten it sectioned.
29,013
I grilled some lamb patties. When I finished, I cranked up the grill to burn off the drippings. I forgot about it. <long time passing> <sniff, sniff> SHEEEEEIT! <runs to turn off grill> I hate the smell of burning paint or aluminum or whatever that is. :(
Charmonium
10,015
3,180
After the storms we had I needed to use the maul. It feels like it's around 8-10lbs. I was trying to free segment of the stump from a fallen tree. I remember thinking I really need to put an edge on this but I guess what I really need is a splitting maul. I don't think I'd ever seen one until I just looked it up. I think that would do nicely. Especially since I only got part of the stump. I don't want to go at it with the chain saw since it's partially buried and I don't want to run the saw in the dirt. But a nice sharp splitting maul should do the job.
12,648
We're getting like 15cm of snow overnight. I hate having to deal with snow in the morning when I'm all dressed formal for church. Probably going to end up having to get up earlier so I can get the car ready and deal with that. When they announce 15cm it's usually more like a foot.
29,013
Spanglish is a term used to describe the fluid mixture of Spanish and English spoken in many parts of the U.S. Metriperial? Engtric? Metrard? What shall we call your blending of units?
lxskllr
58,008
8,242
Without seeing exactly what you're dealing with, you might be better off with a heavy axe. A proper splitting maul isn't really sharp. It has just enough edge to bite into the wood, and the weight/profile wedges the log apart. IOW, you aren't cutting per se. You could put a sharper edge on it, but that would be nasty trying to swing it accurately, and it'll wear you out. I'd look for a used beater axe for hacking in the ground, but even a decent new American axe is only ~$50. I'd suggest harborfreight, but I haven't had luck with Chinese axes. I thought "A chunk of steel on a stick is simple enough. How could they fuck that up?". Well... They managed to fuck that up :^S
Btw, wood is a nicer handle. Plastic handles are blister machines. If you're really gonna be abusing it, plastic might be the way to go, but wear gloves.
Reactions: Charmonium
Sonikku
15,745
4,563
Ordered a case for my phone... And got the wrong one. Now I need to push a button and ask for a refund. :(
What was advertised;
What was received;
12,648
Easter time seems to be the weirdest as far as holidays go. Some companies give the Friday, while others give the Monday, sometimes even within the same company it's different. Like one half of my company gets the Friday and the other gets Monday. It makes those two days a pain for whoever is working because not all the departments are open.
I start nights on Monday so I won't really be affected.
12,648
I still need to shovel the driveway, was going to do it today and didn't feel like it. There's not really that much snow, I'm just getting kind of fed up of winter.
It would be nice to plan a trip to Cuba or something around this time of year just to get a break, but then I'd have that much more shoveling to do when I get back.
29,013
I stuck my thumb drive into the wrong hole. ah heck encrypted it without asking me. I didn't lose anything but what the hell kind of admin sets things up that way?
Charmonium
10,015
3,180
The network card in one of my main computers died. At least I think so. One of the ports is definitely dead. Fortunately Amazon claims to be able to get me one tomorrow - I ordered several hours ago EDT. The m/b in that machine must be pretty old. I thought most m/b came with onboard network adapters.
29,013
We've been catching and relocating packrats using a small havahart trap. We caught five very quickly. This latest one has stolen the bait and triggered the trap w/o getting caught several nights in a row. Now we're thinking that it isn't a packrat but something bigger like a norway rat.
