what file system for my 3.2 HD?
sniperruff
11,644
well im planning to set up my old ancient computer for my mom to watch movies and such, here are the specs...
P233
128mb SDRAM
4gb WD HD (3.2 actual)
well i just wondering whether i should use FAT or NTFS? seems like i'll be installing Win2000 (i can choose from XP, 98 or 2000) on it...
so any thoughts?
AnMig
1,760
---waiting for the NTFS vs FAT file system war :D
I like to use FAT file system for my operating system partition because I sometimes like to bring out my old ghost program that doesnt support NTFS, newer version however does.
I use NTFS for my storage drives since I can capture files that >4gb (limit for fat) useful for video editing and capturing tv shows
personally with a old 3.2 hd I would go fat
chocoruacal
1,197
You won't be watching many movies on a 233mhz chip. Go w/fat32 and 98SE...you'll need all the free RAM space and CPU cycles you can get.
WHipLAsh13
1,719
Computer System Requirements for Windows 2000 Professional:
133 MHz or higher Pentium-compatible CPU
128 MB of RAM is strongly suggested. 64 MB of RAM recommended minimum; more memory generally improves responsiveness [4 gigabytes (GB) RAM maximum.]
2 GB hard disk with a minimum of 650 MB of free space. (Additional free hard disk space is required if you are installing over a network.)
CD-ROM or DVD drive
VGA or higher resolution monitor
Microsoft Mouse or compatible pointing device
28.8 Kbs modem or faster with current Internet connection
Windows 2000 supports single and dual CPU systems
Computer System Requirements for Windows 98:
32-64 MB of RAM is strongly suggested
Hard disk with a minimum of 295 MB of free space
CD-ROM or DVD drive
I would go with 98. You will get alot better performance out of that setup.
DrVos
1,085
What kind of movies are you planning on them watching? Even with a decoder card, I'd doubt that computer could play DVD's well, and Divx is out of the question. I'd recommend at least a PIII 600.
dml54
139
Tryed to watch DivX and DVD on a K6 233Mb with 192Mb RAM and a 32Mb PCI Radeon AIW and it wasn't worth it. I tried Win98SE, WinME, Win2000Pro on the machine and 98SE with FAT32 was more responsive than WinME with FAT32 and Win2000 with FAT32 or NTFS. Go with Windows 98 SE and a FAT32 partition, just don't plan on watching much for movies
txxxx
1,700
Originally posted by: WobbleWobble
Windows 98, 98SE, ME would be better suited for that system than Windows 2000.
Not true. Ive ran Windows 2000 Pro on a P233, it was significantly faster for general day to day running.
modedepe
3,474
Go with FAT and win98. I've had similar setups with both win98 and win2k and the 98 setup was definitely faster.
WobbleWobble
4,867
With the amount of RAM he has? I still think the 9x kernal based OSes are better.
txxxx
1,700
Yup, ive done the same, I know personally.
WobbleWobble
4,867
I've tested a similar setup as well and I personally felt that the 9x OS was faster.
sniperruff
11,644
thanks for all the replies guys...
well considering the win98 is not SE...
and the movies my mom will be watching... they are realmedia or DivX... well its for my mom so speed should not be a matter
heh maybe i'll just try 98 first and if it's too buggy then i'll go with win2k
thanks a bunch
