what fan is better?
GalvanizedYankee
6,986
? What fan(?) is better ???
You might want to edit the title to HSF.
The Ninja is a jumbo HSF and works very well and the one you linked comes with a 120mm fan.
The 64Pro is more reasonable in size, works very well also, has the same vertical installation as the Ninja and uses a rubber mounted 92mm fan.
If you have room for the big guy, go with it. If not spend less for the 64Pro.
Your call...They are both good. Read some of the stickied reviews at the top of this page, then decide. The Ninja might have compatabilty issuses the 64Pro might not have. Investigate that. Go to thier respective sites and look in the support section of each.
...Galvanized
Mrvile
14,066
Like Galvanized said, both are very good heatsinks for their price. The Ninja is more expensive and bigger but outperforms the AC Freezer. So just go with what you can afford/fit in your case.
