What fan for P4 2.4ghz 800FSB Chip?
ScAndal
630
I'm going to be ordering this chip pretty soon and my only concern is sound. I want the quietest cpu fan available. I will not be overclocking, so doesn't have to be any supercooling going on.
What do you guys/gals suggest?
ScAndal
sempurp
I have the same chip together with a Zalman CNPS 7000-AL CU and I am very pleased. With the 92mm fan at about 2000rpm you can barely hear it, and it keeps my cpu in the 35-50 degree Celcius range.
infinite012
817
that's a pretty big range...now I'm getting kinda scurred to move to Intel-the master of the dark side
GtPrOjEcTX
10,784
I have this one as well, but I had to bump the voltage on my overclock so temps are higher. 38idle, 58load.
anyways, get that one or the all copper version or the slk-900 and get a large quiet fan.
text
WaTaGuMp
21,207
2,506
No overclocking = stock HSF unit. They work fine and they arent loud, if you do get a different one you can always get any fan you like and use a Zalam fan mate to adjust the speed to the noise you like.
Those things run about 7 bucks.
