What fan for my case?
Motero
889
I have an Enlight 7237 case with the built in factory fan in the front. It is a little cool in my case, but I want it to be cooler. Does anyone have an opinion on which fan I should get for the back end of the case? I want it to be rather quiet and push out a good bit of air. Also, please let me know where I can purchase this fan at.
Thanks!
JohnnyTT
293
First you have to figure out what size fan you can fit.......80mm, 92mm, 120mm
Probably the 80.
Check out these 2 stores.
2CoolTek
3dCool
I have mostly Sunon fans in my cases. They are solid fans. They also come in 3 flavors; slim, regular, and high output. They are not too loud, I have 8 in my 750 and they make a nice hum.
MWink
For extremely quiet and good cooling I recommend Colorful fans. I use them in my In-Win case and I can't tell if they are on or off. They do push an impressive amount of air. If you want extremely powerful and somewhat noisy then I strongly recommend Nidec fans. They really push a lot of air and don't make too much noise considering the air flow.
