What fan for FOP38??
Casanova
119
I just purchased a tbird 900@1.1 gig w/FOP38 minus fan. Is there a good fan out there to mount on this that has good performance and won't be much louder than my PS? Should I go 60mm(perfect fit) or an 80mm? How exactly would I get an 80mm mounted properly on this cooler? Thanks for suggestions!
DW
Budman
The quiet fan makes it a FOP-32,if you want a FOP-38 you need to put a 7000rpm black Delta fan on it.
Btw this is off topic,next time please use the Cooling forum
