Originally posted by: JulesMaximus
Originally posted by: cavemanmoron
Originally posted by: jumpr
Is it harmful to do it a lot? I'm just getting used to driving manual, and it would help for keeping my speed on hills. Can I do it pretty much whenever?
SURE
shift into 1st gear at 60 mph,on a normal car and you will need to have some extra $$$$.
shift down to 1st gear at 30 mph at the top of a hill,no problem,usually,
Unless you drive like a truck,that 1st gear is meant for 10 mph,
{called "Granny gear" }
read the owners manual?
also the type tranny matters a bit.
My Camaro i can shift down to 2nd at 45 or so
my Chevy Pickup,i cant shift down to 2nd till about 30.
This is because of the lower rear end gear in most trucks. Better for hauling/towing heavy loads.
Sorry but the rear end ratio on my Camaro is 3.50,and the rear end ratio in my p/u is 3.42.
the
tranny/transmission
is whats different.
the first gear ratio in my Camaro tranny is a bit higher than in my truck,
also my truck has a 5th gear overdrive,and the 67 Camaro is a 4 speed muncie.
The air brakes questions,air brakes work on "current" trucks,
like those built in about the last 35 years basically;by having heavy duty springs,that apply the brake
pads,when the air is released,by pushing on the brake pedal.
These were called "safety" brakes a long time ago.
If you are driving a vehicle with air brakes,on the old style setup,and the air compressor stopped working,like if a belt broke,etc,you had little chance of stopping the vehicle,as the air pushed on the brake pads.
The newer style,weather drum or disc,when you lose air pressure,the brakes automatically apply,because of the spring pressure,and stop the vehicle,normally the air pressure is lost slowly,and you have a warning light/loud alarm in the cab,to warn you to pull over.
Sometimes an air line to a trailer will burst,and the trailer brakes come on fully,and then its a dangerous/scary stop for the truck driver.Its still safer than having no brakes due to no air.
The railroad was using safety brakes for years before the trucking industry was mandated to.
