what exactly is ASP?
Chooco
Banned
Apr 5, 2002
731
when you make something in DreamWeaver it makes it an ASP file by default but you can also save it as HTML if you want to. i read the code of the ASP file it made and it's all HTML.......so then what is ASP?
DaveSimmons
40,730
670
Active Server Pages, microsoft tech that has the web server process the page and interpret any script code (between < % ... % > ) before sending the page to the browser.
neuralfx
1,636
correct. its Active Server Pages, server side scripting. Basically you can make dynamically produced web pages possible. Its more heavyweight and open source rival is PHP.
-neural
joohang
12,340
ASP is an ISAPI filter (asp.dll) that allows IIS to interpret the embedded scripting code through a scripting engine - JScript, VBScript, or PerlScript - to dynamically generate an HTML/text output.
In most cases, ASP is suck.
And now that ASP.NET is out, learn that instead.
badxcow
72
just another server side language. learn php and mysql first, then pick up asp. asp is pretty damn easy compared to the php and sql duo.
