Originally posted by: Corsairpro
your GF's virginity alarm was disabled?
Originally posted by: OrganizedChaos
if the comp will let it run ignore it you don't need it. knock sensor is a micophone that listens for knocking caused by cheap gas and will retard the timing a few degrees
what he said, but you shouldn't ignore it. knocking is not good for the engine at all. it's probably just a cheap $10 sensor that you can replace yourself anyway.
Check the year/make/model of the thread....Year/make/model and MAYBE we can help.
