Oh right. So essentially, it's like a patch panel or manual switch box. You select port 1 to connect to port 16, etc.
As it's protocol independent, presumably that means it can't route or switch in a directed manner (like, say, an ethernet switch) - unless there is a gross problem such as a disconnected fiber, in which case presumably it could detect that and implement a pre-programmed work around.
