What else do I need for my honeymoon
TraumaRN
6,893
63
Headed to the south pacific for my honeymoon in a couple months, with my birthday coming up I want to ask my fiance to get me something photography related for our honeymoon.
Here is what I own...
Canon Rebel XT with the base 18-55 lens
plus a canon 28-90 lens, two polarizers and two UV filters.
Powershot A710IS
I don't have a camcorder which was one thought, but I was also thinking maybe an entry level telephoto lens? Like a 75-300? or 55-200? I know I'll be shooting alot of landscapes and sunset/sweeping vista type shots.
And price wise, when I say entry level I mean like $250 would be the max on price, maybe a few bucks over, but we are planning a wedding and do unfortunately have a bit of a budget.
Thanks in advance.
randomlinh
linh.wordpress.com
honeymoon? T1i... photo and video ;)
but your budget is a little tight.. $250 including everything? I'd say the XT+18-55IS might be doable used. but def go for the IS version of the lens. the IS is just a bonus, it's a pretty good lens for what it is.
though, you're talking about telephoto too, so I'm guessing the 250 is body only? if so, XTi's are ~$300 used, go for that if you can.
TraumaRN
6,893
63
No no no, I already have a rebel XT with 18-55 and 28-90 lenses with polarizers and uv filters for each and the Powershot A710IS
What I want is a telephoto lens for this trip, either 55-200 or 75-300 with a pricetag under $250 if possible. Sorry for any confusion
996GT2
5,212
The best budget telephoto in your price range is the Canon 55-250mm IS. Great image quality and image stabilization, which frankly is almost a necessity on longer lenses.
Best part? You can find it for around $225-250 new.
The 18-55 and 55-250 will cover most of the shooting you need to do.
If I were you, I would actually sell both the 18-55 and 28-90 you have, since both are very average lenses that produce "meh" results. The 28-90mm range is also not very useful on a digital SLR with a sensor smaller than a 35mm film frame.
You can get an 18-55mm IS (around $100 new on eBay) with the money from selling the 2 lenses you have, and the 18-55 IS not only adds image stabilization but also improves greatly on the optical formula of the original 18-55. The result is that you will be able to shoot at shutter speeds as low as 1/3 sec at 18mm, which is great if you want to do light trails and such without a tripod.
Also, with the 18-55 IS and 55-250 IS, you'll have a complete wide to telephoto range covered, with IS along the entire range.
randomlinh
linh.wordpress.com
doh, i completely misread, haha. and what he said.
twistedlogic
606
The only telephoto lens (with IS) that will fit his budget of $250. :D
Reach gets expensive and I wouldn't go without IS on a telephoto.
996GT2
5,212
Depends on what you use it for. Since I shoot moving things with my tele, IS is not as important. That's why I personally prefer my 70-210 USM for its much faster AF and faster aperture.
