What drivers do I need for Conroe and fresh XP install?
davidos
908
Are there dual core ones like the AMDs? Or is it just the Win XP dual core hotfix? Thanks!
Madellga
713
1) Intel Inf pack for 975/965 chipsets
2) Network Driver for your mobo
3) Intel ICH7 AHCI or Raid drivers if you use them. You might need them on a floppy for a fresh install.
They should come with your mobo (in a CD). You can also download the latest version and install them instead of upgrading later.
No specific CPU drivers like AMD. Speedstep works out of the box, just set the Energy settings to Minimum Power and have EIST activated on BIOS.
Baked
36,052
17
The only driver you need to load during WinXP installation is the SATA controller driver. Everything else you can download from their respective manufacturer website.
WinXP Pro SP2 is fully compatible w/ C2D.
JAG87
3,921
the dual core fix is needed on any multicore platform with windows XP.
that is if you use old programs or games which cannot handle the 2 cores properly. then Windows automatically loads only one core, and the program behaves normally.
Golgatha
12,399
1,072
Originally posted by: Alisha
Is the windows xp x64 worth upgrading for the C2D
I'd say no, mainly for compatibility and lack of mature drivers. Wait for Vista if you want 64bit.
davidos
908
Is the SATA controller driver necessary if I am not using RAID? On Gigabytes website there are 4 downloads: Audio, Chipset, LAN and SATA RAID...
Do I need the SATA RAID if I am not using RAID? or is is SATA and RAID (2 things in one driver)
Baked
36,052
17
Yes. I had the HD plugged into one of the purple SATA sockets, which is controlled by the JMicron/Gigabyte controller. Loaded the Gigabyte driver I got from Gigabyte's site during WinXP installation, then switched the HD over to the orange sockets, which is the chipset Intel controller, after WinXP and all its updates were installed.
