What drill bit to use to make a keychain from a dead 1.2GHz Athlon?
DARTH_MAUL
384
Title says it all. I am trying to figure out what drill bit to use to drill a hole in a dead 1.2 Athlon. I tried Cobalt bit but, it just slid around. Any help would be great.
DARTH_MAUL
384
So you have used a carbide bit and it worked on an Athlon chip?You have me wondering now if it was carbide not cobalt that we used. Is there such a bit?
medic
Very small cobalt bit in a drill press would do it!
Maybe Titanium or Zirconium?
Johnnie
May 28, 2000
8,444
carbide will cut most athything.. just go slow... what size ya need.. ??
carbide is better than cobalt..more expensive though
DARTH_MAUL
384
not to sure. I just need a small hole big enough for a keychain or necklace size to hang from rear view mirror. I am really wondering now if it was a carbide bit that we used..hmmm is there sich a thing as a cobalt bit. if not then the carbide bit in the drill press we used was a no go
Johnnie
May 28, 2000
8,444
you prob used cobalt.. was it gold in color.. ??? if so...cobalt..carbide is alot heavier..and more brittle.. got to be very careful drilling with it....
WebDude
1,648
Carbide bits are also know as masonary bits. Usually have 2 carbide cutting flutes soldered on to a steel shank. They look a lot different than hs steel or cobalt &quot;twist&quot; drills. They can cut through masonary or brick, but you often get a rough looking hole. You could clean it up with a carbide end mill, chucked in a milling machine (and you could bevel the edges of the hole at the same time with the right tooling). Problem would be holding the Tbird chip solidly enough to prevent any vibration or chatter, without at the same time crushing the chip. If you want to send it to me I'll play with it and see what I can do.
WebDude
DARTH_MAUL
384
Ack no one seems to have carbide....:-( Actually the bit was heavy and no it was not gold. Maybe it was carbide we used. Any other suggestions?
Johnnie
May 28, 2000
8,444
i have a solid carbide bit... used to drill tooling steel.. if it was carbide..it would have cut through the cpu...
Johnnie
May 28, 2000
8,444
hey webdude.. what do you think..carbide will drill most anything ..right ?? :)
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Saw a pic where the pins had been sanded down and a solid copper wire soldered across the nubs on two adjacent sides with a loop at the corner- easy.
Or I'd try grinding a small hole with a rotary burr in a dremel, ceramic is difficult to drill, and brittle.
