What does Windows 10 not understand about "defer upgrades"?
And speak of the devil, Microsoft has now pushed out Creators Update to everyone who had been deferring it. So now you have to take it.
Yep, just came across this today. Even though I had defer on, it still decided to download it for all the machines.
Now luckily this was a small client, but 6 machines over a 5Mbit dsl service is painful.
Well one good side affect of this is, I found out the WSUS settings where not working properly.... groan
They had to push the Creator's update, since the EOL'ed the older versions of the OS.
So, you can't defer forever...
Tonight my PC tried another update on its own, and I fond it hung as usual. Luckily power cycling (twice) again still booted.
Not sure when one of these times it won't.
I'm wondering if I have one option. I'm assuming it's a hardware issue, likely bent CPU pins. But one thing to try would be re-installing the OS.
I think there's an option to 're-install the OS but keep your files'. I'd be interested in trying that, but am thinking that might break the OS and leave the PC unbootable where at best I can re-install again but not keep my filed and I don't want that.
Wondering if there's any reasonable option for trying it and being able to restore if needed.
I haven't found any backup system I like. I found one I used once where I backed up some text files I want. It seems impractical to backup 1.5TB of mostly games, though I think I have less than 50% disk used.
That's the thing though. Win10 AU is not EOL. It's a Long Term Service Branch that's getting 5+5 support. Microsoft is going to be supporting that until 2026!😱
Interesting. I don't recall deferring CU, don't have "defer upgrades" checked, but no CU has shown up so far. Checking for updates does have the "do you want to be among the first" remark as before.
Microsoft apparently always, always fails to do what the customers want. (To be fair, I won't tell them what I do desire.)
I know that you've mentioned potentially bent pins before, and I was curious - can you "Restart" your PC from Windows, and will it restart properly?
IOW, is the issue the updates, or is there a fundamental problem restarting your PC anyways, and it's just the restart cycle during updates that triggers it.
Linux would be your friend here. No forced updates and doesn't invade your privacy.
Windows 10 1511 will be retired on October 10, 2017, AU is 1607 I think it was.
The Win 10 LTSB is only for Enterprise (IIRC), and AFAIK, you can defer critical updates forever on those.
Also the way I had understood how the defer worked, was when the next release was available, in this case Creator Update, then it would defer from that point that MS made it available to everyone like this past week and not at general release
Just happened again, forced upgrade, hung, rolled back, hung, now it's running. I'm not sure what's going to happen eventually over it not being able to upgrade but the only solution I know is probably replace an expensive CPU and pay for a rebuild. Hundreds of dollars.
If you think that there's a hardware stability issue, then doing anything significant with the OS is a really bad idea: you'll likely just end up with more of a mess than you started with.
Investigate the stability issue first, then determine if there is still an OS issue.
It's simple: runs stably, unless rebooted, generally with a patch/upgrade. Those always get a hardware hang and have to rollback except maybe small patches.
If you're asking for an opinion for what hardware could be faulty, it could be a number of things.
Didn't you do a thread recently about stability issues?
Ya, same issue, with my suspicion that there might be some bent CPU pins. No idea what else it could be.
Can we clear this up (at least for now): Did you actually see some physical damage such as bent pins or not?
From my first attempt to build, the CPU had sliding around on it by the big artic cooler heatsink, and would not use some of the RAM banks. I inspected it and saw some bent pins, a few.
I looked at a number of possibilities for fixing them - I did not feel I could fix them after trying, and that would make it worse - and the only service I found was a jewelry store.
They 'tried' to fix them but admitted they were pretty limited in how much they could do. After their attempts I'm just not sure how bad it was. I'd say not perfect but not sure. I put it together again and now the RAM worked, but I've had this hang after a reboot/patch ever since.
The nice thing here is that bent pins are on the board (if I remember your build correctly) not on the CPU. So ~$100 to get to a perfectly working computer may be worth it. In the words of VL, "Just sayin'..."
Come to think of it, you're probably right - so it'd be $175 for the MB plus however much - $100? - for rebuilding it, since I don't want to repeat the same thing and deal with the CPU installation issue. If it were only $100, I'd probably do it.
Microsoft is trying to make en enemy. Tonight it rebooted without any warning other than a window to close about a half-hour earlier, just after I had typed in an unsaved article.
No, they just don't give a crap about users (beyond what is absolutely necessary to keep most of their user base). I would have thought that was rather obvious.
I wonder if it's possible that your attention was diverted while typing and pressing say the Enter key caused a message to disappear immediately after it appeared.
Also, Win10 has a 'quiet hours' feature during which time it's OK for MS to reboot the machine for updates. Admittedly the feature needs a lot of work, for example complete flexibility in choosing which hours (including all of them), but it's better than a machine that just reboots of its own accord.
Microsoft really goofed badly when they implemented this update scheme. I mean really, it is bad enough that Windows has to reboot many times while updating.
I use Manjaro Linux which is a rolling release distro and I don't have to deal with forced or updates or multiply reboots at all.
No, I think nothing popped up. I'd typed in the article and was IIRC sort of just watching the screen when poof. There's a chance I missed a popup, and that hitting anything caused it to reboot, but it didn't seem like it.
Of course, that was one of three reboots of the day it forced - but only one with no warning.
And it wasn't like a crash, it cleared the screen and indicated it was the patch process doing it.
