I was thinking about buying some oil paintings from http://www.toucanart.com/, and as an ordering option you can order the painting stretched. What does that mean?
Here is what it says in the fact on that page:
I assume if I order the paintings "stretched" they will come on a "stretcher frames"?
What is a Stretcher Frame?
A Stretcher Frame is the wooden construction used to mount the canvas on in order to stretch the canvas of the oil painting thoroughly. The result is a smooth surface of the oil painting. The stretched painting can thereafter be attached to a 'real frame' or hung on the wall without any additional framing.
A stretcher frame is made out of four wooden bars which are connected at every corner by mortise and tenon joints.
