What does FSB Spread Spectrum do, technically?
Gerbil333
3,072
Is the most stable option Disabled? I'm figuring it is since it is forced off when OC'ing, but since I don't really know what it does, I can't make a decision.
tcsenter
18,903
555
Adrian Rojak's Bios Optimization Guide:
Spread Spectrum
Options : Enabled, Disabled, 0.25%, 0.5%, Smart Clock
When the motherboard's clock generator pulses, the extreme values (spikes) of the pulses creates EMI (Electromagnetic Interference). The Spead Spectrum function reduces the EMI generated by modulating the pulses so that the spikes of the pulses are reduced to flatter curves. It does so by varying the frequency so that it doesn't use any particular frequency for more than a moment. This reduces interference problems with other electronics in the area.
However, while enabling Spread Spectrum decreases EMI, system stability and performance may be slightly compromised. This may be especially true with timing-critical devices like clock-sensitive SCSI devices.
Some BIOSes offer a Smart Clock option. Instead of modulating the frequency of the pulses over time, Smart Clock turns off the AGP, PCI and SDRAM clock signals when not in use. Thus, EMI can be reduced without compromising system stability. As a bonus, using Smart Clock can also help reduce power consumption.
If you do not have any EMI problem, leave the setting at Disabled for optimal system stability and performance. But if you are plagued by EMI, use the Smart Clock setting if possible and settle for Enabled or one of the two other values if Smart Clock is not available. The percentage values denote the amount of jitter (variation) that the BIOS performs on the clock frequency. So, a lower value (0.25%) is comparatively better for system stability while a higher value (0.5%) is better for EMI reduction.
Remember to disable Spread Spectrum if you are overclocking because even a 0.25% jitter can introduce a temporary boost in clockspeed of 25MHz (with a 1GHz CPU) which may just cause your overclocked processor to lock up. Or at least use the Smart Clock setting as that doesn't involve any modulation of the frequency.
Gerbil333
3,072
Thanks :) That's pretty interesting. I'll leave it disabled since it's faster and more stable that way.
tcsenter
18,903
555
Holy plagarism, that's a direct copy and paste from an MSI manual.
Or that portion of the MSI manual is a direct copy and paste from the Optimization Guide.
IIRC, MSI was already caught pilfering artwork for their retail boxes and websites from graphics artists who had posted their work on the internet. Don't know if that ever turned out to be true or not, but that was the rumor for a while.
Gotta watch these Chinese companies.
