EDIT:
so I went to Toyota dealer and bought a TPS. went to my mechanic today and he said my original TPS is fine. so I went back to the dealer and they say they do not accept returns on Electrical Component (it is actually written in 36-sized font on the invoice.) I got ownzedddd....
this is the definition I found on line...
recently i am experiencing a 10-15% drop in fuel economy when the engine light is on; and when its off, gas mileage go back to normal (roughly). I checked the ECU with an OBDII reader, and it reports the engine light is due to failed/shorted Throttle Position Sensor. The light been on and off for quite some time.
Now, my question is,
1) does fuel economy has anything to do with the TPS?
2) other than lowered fuel economy and reduced horsepower, do you recommend changing the TPS? It costs 95 bucks from Toyota dealer. A Mechanic recommends the OEM one coz afteramarket ones just don't work right.
my car = 1996 Celica. 7AFE.
First a little lesson on what the TPS(throttle position sensor)does for your engine. The TPS(Throttle Position Sensor) monitors the throttle valve position (which determines how much air goes into the engine) so the ECU can respond quickly to changes, increasing or decreasing the fuel rate as necessary. The TPS is really just a potentiometer or a variable resistor not much different than the volume knob on your radio. The voltage to the ECU from the TPS changes in proportion to how far into the gas pedal you are.
