- Jan 12, 2005
- 9,500
- 6
- 81
I know this subject has been beaten to death, but it seems like no one really knows the answers:
My understanding is that the "extra" four pins on the NF4 power connector are intended to supply power directly to one (both?) PCI-e Video slot(s). I can understand that, for a dual-rail PSU, those four pins represent one of the rails (and I assume the other 20 pins represent the other rail).
But what happens when you use a single-rail PSU with a 24-pin connector? Is the connector simply taking whatever power/amperage is needed for the PCI-e slot out of the total amps available from the single rail and shunting it to the extra four pins? Or is something else happening. And if you use only a 20-pin connector, how is power delivered?
In the discussions up to now, it looks like a dual-rail PSU is NOT a good idea for use on SLI boards, since one of the rails can be over-burdened. But if you use a 24-pin connector on a single-rail PSU, does this artificially create a dual-rail PSU, and will you run into the same problems?
Again, sorry. But I don't think these sorts of questions have been specifically addressed.
