20 dBa + 21 dBa + 20 dBa = 62dBa? 21dBa? How do decibels add up?
Is it just the loudest one that overpowers all the quieter ones, meaning it's 21 dBa?
What if you run 5 20dB fans at the same time compared to 1 20dB fan? Same noise or 5 fans make more noise?
Right now my NB and my GPU are passively cooled, the CPU has a 20dB 92mm and the PSU and out take has 21dB 80mm's.
So, can I make it quieter without doing volt mods? How are these insulators? Buy or no good?
http://mirror.memoryexpress.net/ProductDetail.php?DisplayProductID=3595
It's $7 for 2.
Is there really a difference in noise having a OEM case grill compared to cutting it out and putting another grill 2mm away from the fan?
Simon
It's $7 for 2.
Simon
