I want to use a yet to be built computer as an audio effects box. Via the RME Hammerfall HD96/54 I will Either plug 12 in (ADAT) and 12 out (ADAT) or just 24 in and record all to the harddrive.
With 12 in and 12 out at 24bit/96khz, I would add real time audio effects (Maybe multipule per channel) without ever writing to the internal hardrive.
What is important for this to work? I've heard a fast processor, but what about ram? The signal is just passed through the Computer so I don't know whats important and not.
Conversly, If I wanted to send 24 tracks of 16bit/48khz into the computer (add real time effects) and then record those 24 tracks to the hard drive, how fast does my hard drive need to be?
I've been leaning towards a AMD 64bit processor, maybe the 3500, but do you think this will be fast enough? Is AMD vs. Intel a mute point here or is intel better?
Any other recommendations?
Thanks
Mongoo
Thanks
Mongoo
