What do I need to buy for PPPoA dial UP Home Network
ChiknHead
646
title says it all. I have a Speedstream 3060 internal modem now.
I need to share internet/printer with another PC. I cant do the 2 NICS and
crossover cable method I need to go another way. Help anyone please.
Thanks
JackMDS
29,552
429
The best solution is to buy External Ethernet DSL Modem, and a Cable/DSL Router.
Such a solution will cost you about $190.
Otherwise, it is double NIC with ICS, or Sygate that claims to work with one NIC.
Sygate® Home Network
No other magic is known.
ChiknHead
646
The problem I think I have is...
Im on PPPoA dialup DSL connection.
Will I be able to "dailup my connection going
thru a router to the modem?
JackMDS
29,552
429
The Modem has to come before the Router. Unless you have External DSL Modem , you can not use Hardware Router.
ChiknHead
646
I dont have external yet, but I dont mind buying one I just need to
make sure I buy the correct hardware. I didnt know if my computer
could find the modem to dialup if it had to go thru a router to find it.
If thats not a problem, then Ill buy an external dsl modem and a router.
dbwillis
Banned
Mar 19, 2001
2,307
If you have an external DSL modem (or get one) and router, the router can do the 'dial up' and connect the DSL.
I have a Efficient Networks or SpeedStream DSL modem (forgot which one) and a Linksys 4 port, the router keeps the DSL line on all the time for my 3 PC's
ChiknHead
646
k thats what I needed to know. Thanks for the info. You dont happen to
have Bellsouth DSL? (FastAccess)
neuralfx
1,636
get the Alcatel Speed Touch Home, it will cost exactly $125 from BSFA or you could try to save 10$ bucks on ebay. The linksys befsr41 is a good choice, yes I believe it supports printer sharing .. well hope this helps, good luck ..
-neural
