What do I need for Cooling?
aaa187
I currently have a case that came with 3 fans,
http://www.newegg.com/Product/Produc...82E16811147060
One on top
One in the back
One in the front.
There is an option on the side for two 120mm fans.
I have my i5 3570k currently running with the stock fan.
I Will be installing a GTX 660 ti soon, so what coolings can I add to my system?
ONE BIG QUESTION:
I have my PSU with the fan up inside my case, there is an option for it to sit with fan facing down.
Should I switch it upside down?
I don't think you will need extra cooling. Three fans should handle a 660 Ti easily, it is not a high wattage card.
I would switch the PSU upside down just to separate it from the case airflow. I like exhausting hot air via the top and rear slots only
