What do I do when it says "No operating system found"?
Zclyh3
Banned
Read title.
Oh yeah..it's a problem with the hard drive...it has an OS in it, but this shows up when I boot up the computer. I don't know what to do..maybe I should go read my A+ Certification booklet that I bought....last year.
Before Format/Reinstall you might want to try this:
Make sure your HD is being picked up correctly in the Bios:
if everything in Bios is good,boot with a startup disk in Drive A:,and do the command "sys C:" without the "".
If that don't do the trick,Boot form Floppy disk again and check out to make sure that your HD is set to Active partition in fdisk.
type "Fdisk" without "" to get into Fdisk utility.
if drive is set to active,and all above has been checked,it could just be your cable.change cables then try again.
other then that,it could be a boot Virus,or you may need to Format and Reinstall.
Good Luck.
[Edit]Info above is only for the Win9x OS.guessing thats what you was running in that HD 🙂 [/Edit]
Shawn.
<< if everything in Bios is good,boot with a startup disk in Drive A:,and do the command "sys C:" without the "". >>
That's something to try if you are running 98 or 95. Don't do this on 2k or XP.
What you should try is booting from the 98 floppy and typing Fdisk /mbr
This will solve the problem, I bet.
