What do I do to fix stablility problems when I'm at stock settings?
rambow
Banned
Dec 6, 2005
188
im just really confused, dont know where to begin so i guess ill post my specs
winchester 3000+ @stock 1.8
a maxtor 250gb hdd which was giving me errors until i ran chkdsk
1gb crucial ballistix
my psu: 500w 34a@12v, has been stable since i bought it almost 2 years ago, dunno if it is the problem, the readings i get from it look normal, even when running prime95
rambow
Banned
Dec 6, 2005
188
heh stability problems...
just about all of them.
i get what seems like data loss and random restarts, and i did set it to stock manually, but i'll double check.
rambow
Banned
Dec 6, 2005
188
no its definatly not overheating, im pretty sure either my psu, cpu, or motherboard are dying, I just dont know which one.
Do you guys know of anything i can do to narrow it down without using windows because I can't even get back into that anymore.
mikeford
5,671
160
Swapping some parts works well, ram then cpu or PS, but first try setting bios to totally lame.
