ok. i've got the EG451P-VE model. 430W w/ 92mm intake fan, 80mm (temp controlled) exhaust.
my case temp is 23 degress so the 80mm fan is at it's lowest setting.
the 92mm fan is not temp controlled (at least to my understanding). at the lowest 80mm speed the 92mm airflow is "overpowering" the 80mm so a good portion of the flow is exiting the vents on the back (inside the case) of the PSU!!
this does not seem like a good thing since this is the warm case air from above the CPU. any thoughts?
